Vance & Hines Short Shot Baffle Opinions
I have a 2011 Street Bob with Vance & Hines Short Shot Staggered pipes. Currently I'm running the standard baffle. I also have a set of the V&H quiet baffles. I'm looking for some opinions on running them with no baffles vs. the standard baffles vs. the quiet baffles (Performance, sound, etc).
I just bought a set of short shots off someone with the quiet baffle installed. They are definitely quieter but still have a good sound. My buddy had a set of short shots on his Low Rider with the standard baffle which I rode so I know there's a noticeable difference. I do not need ear plugs with a FF helmet. I can tell there's a slight bit more pep with the exhaust but I'm still on a stock intake which hurts me.
I have been running the standard baffles for a while now and decided to go ahead and put the quiet baffles in. I downloaded a decibel sound meter for my smartphone but found out the phone has a limiter that stops at 70 decibels so the following results will not bew that scientific.
No baffle:
Sound is very loud and sharp.
Standard Baffle:
As load and sharp as with no baffle, at least as far as I can tell, but I suspect the standard baffle creates some back pressure by slowing the exhaust gases down. You can still see completely through it though.
Quiet Baffle:
Noticeably quieter and a softer more throaty sound but still much louder than stock.
Quiet Baffle - Off the bike idling:
It's as loud as the standard baffle when standing right next to the exhaust but there's no sharp sound.
It's quieter when standing behind the bike at idle 10 feet away.
Quiet Baffle -While riding:
Idle is quieter (Sitting above the exhaust).
Revving the throttle is as loud as the standard baffle.
Cruising at highway speeds is much quieter.
Cruising at city speeds is a little quieter.
I'm going to leave the quiet baffles in for awhile and see how I like them.
Thanks for you feedback!
No baffle:
Standard Baffle:
Quiet Baffle:
Any dealer or Indy should install a set of pipes but will probably charge you $200-$400 to do it with parts (exhaust gaskets) and labor. They will also tell you that you will need the stage 1 ECM download, but if you haven't changed the intake (air cleaner) you don't have to have it. The dealer will tell you that you "need" it and that your warranty will void if you don't, which is all to scare you into spending more money. If you do have a high flow A/C though at a minimum you will need the download. A better route to go is an aftermarket tuner if you are going that way though.
I bought a cobra FI2000 autotuner and it does the job nice. And then no matter what you do from there it tunes to match. Well worth the money.
Now if you're gonna change the exhaust, do yourself the favor of opening up the intake. That paper stock sh*t is a no-no. There's a bunch out there so just go at least stage 1. V&H and Arlen Ness both have nice inexpensive ones and with a easy mod you can use the Harley covers on them. You'll be opening her up nice on the low end and still have some pull in the seat on the high end also.
Hi
No baffle:
Standard Baffle:
Quiet Baffle:
No baffle:
Standard Baffle:
Quiet Baffle:
ShadowforNow
02-25-2019 01:08 PM
