V&H Super Radius Dragging Ground
I have a 2015 SGS with V&H Super Radius Black exhaust. Problem with the exhaust is it drags the pavement making righthand turn. The rear suspension is set up for my weight.. I have called and emailed V&H customer service and get nothing but the run around. They said stiffen the rear suspension but that will affect the ride quality. Their warranty department told me they won't exchange the exhaust because it is used. NO ****. I am very unhappy with Vance & Hines and the crappy service.
Has anyone else had this problem with this exhaust or trying to get help from V&H?
<p>Well, I'm not sure what V&H is supposed to do about the way you have your bike set-up or your riding style. I'm pretty sure their pipes are designed and built for the majority of bikes that are left in pretty much stock condition, not slammed with the suspension set at soft. Scraped pipes are seen in some circles as a badge of honor.</p><p>Good luck.</p>
I've had a similar issue with my 15 SGS. My V&H true dual headers scrap, luckily it is on the underside and only visible if your looking at the bike from ground level, also it is only the heat shield that rubbed not the pipe itself. Good Luck I posted this question last week and the consensus seemed to be, ride more carefully.
clueless
Exhaust System Topics
01-05-2007 05:58 PM
