Sponsored by: Jekill and Hyde
Problem with bike after exhaust install
Old 11-29-2015, 03:20 AM
ok2014sg's Avatar
ok2014sg
ok2014sg is offline
Stage II
Default Problem with bike after exhaust install
I have a 2016 flhxs. I removed the factory air cleaner and installed the screaming eagle billet cut back black intake. Tested the bike after the install and it started. I then installed a thunder header 2 into 1 exhaust. After the exhaust install, the bike will not start and displays the oil light on the dash. it almost acts like the battery does not have enough juice to start the bike. Has anyone else ran into this issue or can anyone tell me the possible cause of the bike not starting? Any suggestions for where to begin trouble shooting? Any and all help is greatly appreciated.
Old 11-29-2015, 05:33 AM
touchdown's Avatar
touchdown
touchdown is offline
Received 1,659 Likes on 946 Posts
Don't know why it wont start, maybe you knocked a wire or something. I do know it will never be right without a tuner of some kind. I use a power commander 5 there are others. Then you need to get it Dyno tuned.
Old 11-29-2015, 05:41 AM
schlacker's Avatar
schlacker
schlacker is offline
Re trace your steps from the beginning of the install to the end, but broaden your scope to examine all of the other components in the surrounding area of your work-it sounds electrical, so I would keep an eye out for damaged/disconnected wiring.
I'm surprised, by some of the things I've missed while re-checking my work. Pinched wires, loose clamps, etc
Old 11-29-2015, 09:46 AM
ok2014sg's Avatar
ok2014sg
ok2014sg is offline
Stage II
I have the screaming eagle racing tuner that I'm going to use to tune it. It's the same setup I was running on my 2014 flhx. I'll take another look at the wires and make sure nothing else is loose. Thanks for the help.
MyFavRk
05-19-2019 02:43 PM
silverado636
09-26-2011 04:17 PM
ernster500
09-21-2011 08:55 PM
mario medeiros
09-11-2010 10:49 AM
07 desert sled
09-14-2007 09:44 PM
Quick Reply: Problem with bike after exhaust install
