Mikuni idle problem?
I recently installed a Mikuni HSR42 on my 06 streetglide and I am having a problem with a rough "shudder" at idle when it is warm. I installed a 22.5 idle jet and adjusted the idle air screw in to about 1.5 turns. I usually ride at 5000' and above and the bike runs great at all rpm's over 1000 but when you are coming to a stop after it is hot,the rpm's drop below 1000 and it shakes hard. I usually blip the throttle several times and the idle will sometimes settle to 1050 rpms but sometimes it continues to shake hard and idle very rough. I installed a new manifold gasket in case I had an air leak but it didn't solve the problem.Any ideas?
Thanks,
2006 streetglide
Vance and Hines oval slip ons
Kuryakyn twin velocity air cleaner
Mikuni HSR 42, 160 main jet, 22.5 idle jet, [/align]
Thanks,
2006 streetglide
Windseeker
EVO
07-04-2019 07:44 PM
