will a 2011 flhx exhaust fit my 2014?
I purchased a set of used rinehart 3.5 inch slip ons(I thought it was JUST slip ons) for my streetglide over the weekend. When I got there to pick them up they were still mounted to his factory exhaust. For 100 bucks I got an entire exhaust for a 2011 streetglide with rinehart slipons,he said just take the whole thing,its not worth his time to sit there and try to remove slip ons that have been installed for 6 years. I polished up the mufflers,yanked em off the old pipes and put them on my bike and they look/sound good. I took his header,punched out the cat and welded it back up and want to install his 2011 header assembly on my bike, I figure since I got it for pennies why not. I thought I read something somewhere that the oxygen sensor bungs are a different size from a 2011 to a 2014. If so,what do I need to purchase/do to make my sensors work in a 2011 exhaust?Any help would be appreciated. Thankyou!
If the O2 holes are a different size you can order the inserts directly from J&P or out of the Drag Specialties "Fat Book". And yes the system will mount directly onto your 2014. You'll most likely need to choose a fuel management device or tuner to adjust the ECU so the bike doesn't start to run in a leaner condition than the factory/EPA tune.
Ok I will do some research and see what I need. I was looking at the thundermax tuner which uses the 2011 style 02 bungs so it would go right into the header I decatted. Just dont know if I want to spend almost a grand on a tuner when Ive heard great reviews on the vh fuelpak and its only 400 bucks.
hobo1
08-02-2020 03:18 PM
