Best true dual exhaust system for high performance 88TC build
Right now I'm running v&h dresser dual system with jackpot 4" slipons. Bike is a 2004 FLHRSI (Road king custom fuel injected).
Engine upgrades are 98" big bore, andrews 26a cams, big sucker intake.
Should I be looking to swap out this v&h header pipe to get the most out of my setup? I want to avoid having anything cross under the frame (bike is low and running true-track stabilizer).
Thanks.
Thanks.
The 95-08 Rinehart True duals don't cross under and they are a stepped head pipe, iirc 1.75"-1.875"-2" and then the mufflers are 2" inlet. Pretty much all other true duals are 1.75" headpipes(some are smaller) and the mufflers are 1.75" inlet. That is the main difference.
