Sponsored by: Jekill and Hyde
V&H Monster Oval on Touring angle?
Old 10-21-2016, 10:02 AM
rob0225's Avatar
rob0225
rob0225 is offline
Default V&H Monster Oval on Touring angle?
Just put the V&H Monster Ovals on my FLHTK. When looking from the rear it looks to lean to the outside a bit and not level. Is this normal for these pipes? Everything is installed properly and there is no way to can't it the other way to make it level and still have all the brackets lined up.
Thanks,
Robert
Old 10-21-2016, 11:02 AM
Bama J's Avatar
Bama J
Bama J is offline
I had a set of those, that's not normal. They should be level. I can't remember exactly how they mounted but I do remember them having their own mounting brackets and mounted differently than most other mufflers.
I'd try loosening the muffler from the headpipe, as well as loosening the mounting bolts at the brackets all the way out until the last thread and see if you can twist the mufflers enough to level out, then retighten the mounting bolts carefully while holding the mufflers in place.
Old 10-22-2016, 08:08 AM
sanman4ever's Avatar
sanman4ever
sanman4ever is offline
Did you use new exhaust clamps?
Old 10-24-2016, 10:14 AM
rob0225's Avatar
rob0225
rob0225 is offline
Fixed. Loosened up the muffler clamps and leveled them, I didn't realize I had any flexibility in the orientation with the way it's designed.
I did use new clamps.
RussW4
12-22-2017 05:34 PM
Chicago Ken
09-17-2011 10:03 PM
kevdog
11-17-2010 03:20 PM
Multi Mile
03-29-2010 11:31 PM
dylanchua
02-26-2009 09:38 AM
Quick Reply: V&H Monster Oval on Touring angle?
