To tune or not to tune
Tune it. Remapping doesn't do much. I would recommend a FP3. There are many other quality options but I like that one. Retails for $400 and probably cheaper online. Easy to use and smartphone compatible. Take it off after tuning or leave it on the bike and use the display on your phone. Should eliminate the pop, increase performance and throttle response.
GOOD LUCK finding a straight answer! I have searched for a solid month trying to get a straight advice on what to do when going to full after market exhaust. I have a brand new set of VH pipes setting at home waiting to go on my 2016 dyna and dont know if I need to spend 500 bucks on a tuner or not. So I have decided to throw them on then see if I need one or not. Some say yes you gotta have one if you change the pipes. Some say no. Some say you only gotta do it if you change the intake. Some say you gotta do it if your seat is black and you drive a moped. So who knows. Will see if my bike blows up because I added pipes to it before I can get a tuner on it then I didnt need it anyway!! HAAHA
You can probably get by without a tuner like some have suggested but the factory sets them so lean from the factory that they run better after being properly tuned, with or without upgrades. I use a power vision and am happy. The pv will allow user programming and work with future upgrades like cams and increased ci where some others don't.
hollandhunter (12-03-2016)
Eddie
So +1 on tuner
billatstarbrite
Exhaust System Topics
03-18-2014 08:31 PM
