which one?????
02-19-2017, 12:38 PM
which one?????
Which exhaust? I have vance and hines power duals with High output mufflers. would it be beneficial to switch to D&D 2 into 1 with ghost pipe.
Would I see any difference in power and performance?
I have a 2013 Street Glide with screaming eagle tire shredder kit and tune.
02-19-2017, 04:27 PM
For sure!!!
The V&H set up is robbing power & Torque from you.
YB
02-19-2017, 11:57 PM
Quote:
Originally Posted by
09 YELLOWBIRD
For sure!!!
YB
02-20-2017, 03:35 PM
If you do it, you won't regret it!
02-21-2017, 10:18 AM
Make sure you retune after swapping pipes
02-24-2017, 03:43 PM
Is it enough power and torque for the money? will it gain torque and loose top end HP?
My numbers now with this set up is 115hp and 120tq. Would I see much more than that?
02-24-2017, 06:42 PM
You'll probably pick up another 7-9 horsepower and about 10 more on the torque curve but there's only one sure fire way to know. The Fatcat is an all around power pipe, probably the best on the market.
02-24-2017, 07:36 PM
Peak numbers might not be huge but your curve should flatten out some.
Ride-ability is much more important then the peak number
tacojunkie
11
07-27-2017 03:47 AM
slayerrffr
Exhaust System Topics
02-01-2017 07:01 PM
mdanehart
06-04-2014 08:46 AM
KG6VVO
01-02-2014 03:47 PM
flhxmc
07-07-2013 01:43 PM
