Valves, and cylender heads
I have a 1980 iron head xlch 1000cc. It's My first Harley. I bought it in December of 2015. I rode it home after I purchased it. The ride was about 120 miles. I blow through a quart and of oil,v and fouled out a set of plugs. My uncle told me it had bad rings and needed a to end rebuild. So 3 days later I bought the manual and tore the top end off, the rings feel out when I pulled the cylenders off. The cylenders were scared deep. I took and had them honed and bored over .020 I ordered the me piston and rings and a complete gasket kid for the bike.
Two days after placing my order I was incarcerated for 12 months for a DUI. While I was in jail, my brother moved the bike to his house. I've still got all the parts and hardware thank God. But he moved the cylenders heads and now I don't know which head goes on which cylender. The bolt pattern is different for the cylenders then self so I can't mess those up. Does any one know off a way to determine which head goes on the front and which go on the back??????????
I am aware that it's spelled cylinder, I wasn't aware that I miss spelled it in the post. Thank you for pointing it out. Now the next obvious question is. How do i know if it's the exhaust side. Both ports seem to be the same diameter. Like I said this is my first build and I am ignorant to this. Any help you could give me would be greatly appreciated. Thank you.
For ROCKOUT information & purchasing please click the LINKS below... For all Twin Cams and Evo Big Twins & Sporsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
