Samson Caliber Exhaust
Has anyone heard any info about the Samson Caliber 2:1 exhaust system? I am considering a new exhaust system and I think I would like to try 2:1's. I have heard alot about Thunderheaders but I saw a picture of the Calibers in a mag. I hope someone has some info. Thanks
RE: Samson Caliber Exhaust
First of all welcome to the forum's, 2nd of all glad to see someone buying some new exhaust to try, I think the caliber exhaust will be a good choice, stepped and 2in1, the best of both world's sort of speak. Let us no after the install hoe they work.[sm=burnout.gif]
if you go to https://www.directparts.com/static/a...thecaliber.htm direct parts has an "article" on the claibur dual system. Sounds impressive but I'm not sure about the objectivity. I have not seen anything yet on the calibur 2 to 1.
Well I got the pipes! I opened the box to inspect and everything was there. It comes with two different baffles, all the hardware, etc. Removed the old pipes, both old mounting brackets, and the old exhaust port gaskets. Cleaned evrything up and started the install. Its tricky to get the pipe on due to it being one solid piece. But it wasnt bad. Then I installed the new mounting bracket, tightened everything up and installed the heat shields. The chrome is flawless. Last thing you do is install the baffle and end cap. The only thing that was not included and that no one at Samson or the retailer mentioned is that you need a shorter boltfor the passenger footpeg. The old bolt went through the exhaust mount and into the frame. So now that this mount is no longer installed the bolt is an inch to long. Other than that it was pretty simple. Took the bike for a spin, the sound is a deep throaty sound. The performance just by feeling in the seat of the pants is a good strong pull through the whole powerband. I will post more info and some pictures later.[sm=burnout.gif]
