New stage 1 Air Filter
RE: New stage 1 Air Filter
ORIGINAL: Behnam22
My question is, is there anything going to get damaged if I don't do Dyno for a while?
Ben
Ben
They say it will run way too lean and melt my valves. I thought that the O2 sensors would automatically adjust the fuel mixture to where it wouldnt do that...but then again I'm not a mechanic, that's just what common sense tells me. Sometimes I feel the Harley dealerships can tell you some bs just to sell their product. Mine doesnt reccommend the PCIII or the V&H Fuel pak...they say they wont even sell them because too many problems in the past.
I'm biting the bullet and letting them do what they suggest (sert, stage 1, dyno)
After all...I did just spend $15,000 on the bike and I just dont want to risk it.
Hey guys. I'm having my 08 FB deliverd in a week and a half. Didn't want the stock exhaust, so I ordered up the Vance and Hynes Big Shot Staggards. With a set of pipes that flow free, to get the benefit from them, you need to go with a free flowing AC. A lot of people here go with the SE AC and switch out the filter to a K&N (part no. HD 0800) This will increase your HP and torgue a bit. With these two changes, you need to get your bike re-mappedat the dealership or it will do damage. This will allow the bike to run cooler. The 07 and 08 are lean to start with, so they run hot and these little mods help. Now, if you plan on doing future engine changes (ie cams) to save money you can go with a SERT, V&H Fuel Pack or PC III. Of course there are other ones available. The PC III seems popular. Fo me, I'm not planning on doing any engine mods for a while at least, so I'm just going with the re-map. I hope this helps a bit. There is a kinds of great info on this forum. You can just surf HDForums to find your answers or use the search function at the top of the page.
ORIGINAL: rockerhead
An engine is just a pump. Let more air in (low restriction air filter) without letting more air out (stock exhaust) equals no change in pump capacity. Get it?
I did all three at once and wish i would not of done the stage one download. I now just have to spend more on a race tuner.
