Sponsored by: Jekill and Hyde
Hippo Build Cam Advice Needed
Old 10-16-2007, 02:40 PM
jnickel's Avatar
jnickel
jnickel is offline
Default Hippo Build Cam Advice Needed
All, this winter I'm going to do the Hippo Build
95 Jugs & flat top Pistons
Screamin' Eagle Pro Heads
SS 570 Gear Drive,
etc, etc.
I was wondering how the build would perform with Andrews cams (55) vs. SS 570. The cams look very similar. The biggest difference I can find is the lift being .550 vs. .570 (S&S). I know both of these cams perform well around 10:1 compression which this build would be.
Insight?
Andrews Info
288155G
55G
22/46
248
283
.550
.197
52/20
252
292
.550
.181
S & S Info
20°/40°
55°/20°
240°
250°
.570”
100.0°
107.5°
.187”
.179”
Old 10-16-2007, 06:31 PM
mentor70's Avatar
mentor70
mentor70 is offline
Default RE: Hippo Build Cam Advice Needed
I would stick with the S&S cams or go to the Head Quarters .575 Firestorm cams for broader power range and more low end torque.
Old 10-16-2007, 07:16 PM
BVBOB's Avatar
BVBOB
BVBOB is offline
You are going to losesome end power with the 55 cams 46 degree intake closing as compared to the S&S 40 degree intakeclosing, at 10 to 1 compression you are borderline for comp releases with the S&S cams, you would likely be around 190lbs cranking pressure and could have some hot restart issues.
Old 10-16-2007, 09:05 PM
PhilM's Avatar
PhilM
PhilM is offline
If you're planning on the Hippo route, then follow it!
I am a huge HQ fan, but I have to say that sticking with stuff that is known to work together makes more sense thanthrowingan unknown in to the mix.
Old 10-17-2007, 01:52 AM
msocko3's Avatar
msocko3
msocko3 is offline
I'm with Phil. If your doing the Hippo then don't deviate from the recepie or your results may not be what you expected. Now if it was me I'd spend the couple extra bucks and do a HQ build.
Old 10-17-2007, 08:37 AM
Kingofcubes's Avatar
Kingofcubes
Kingofcubes is offline
ARE THOSE THE HEADS WITH THE 2.08" INTAKES?
Old 10-17-2007, 08:46 AM
jnickel's Avatar
jnickel
jnickel is offline
I think so. The part num is 16952-06. The "bathtub" chamber with a volume of 72cc
Old 10-17-2007, 11:34 AM
wildbillnc's Avatar
wildbillnc
wildbillnc is offline
I would talk to Steve at GMR or Scott at Hillside Cycle and get a apackage that has been proven to work together but I am also a big Woods cam fan (tw6g) works real good at 10:1
Old 10-17-2007, 03:11 PM
Firetender's Avatar
Firetender
Firetender is offline
The Hippo Build (Thanks Frank!) is the best move I made in my Stage III decision process. I only went with the SE forged pistons at the urging of the builder vs. fly-cut cast pistons. This is a great combination of parts for a touring bike!
Tokkol
Engine Mechanical Topics
07-09-2017 04:32 PM
kryingame
05-07-2016 02:53 PM
ThaGlyde
03-22-2012 07:20 PM
wydopn231
03-01-2008 11:23 PM
HD Attitude
17
11-25-2007 10:12 AM
Quick Reply: Hippo Build Cam Advice Needed
