103 Compression Ratio
RE: 103 Compression Ratio
The SE catalog list the cast flat top pistons with the 103 /stock heads produces 10:1 compression . I believe these are the pistons used in the Stage II kit I'm running. ( page 18 of the Intake/Carb Engine/Engine component catalog )
As doc says , it isn't an absolute ..
'07 and '08 police model Touring bikes have factory 103" engines; the specs for those show 9.6:1.
You can probably get your dealer to do a kit break-down comparing the Stage I and Stage II 103" kits for the 96 and see if the pistons are the same in both.
Nidan: Which SE parts catalog has the 10:1 info? I ask because I have the '08 SE Pro Racing Parts catalog and it doesn't give a CR for the cast flat-top 3 7/8" bore pistons, PN 21966-07.
