Rocker Arm End Play
Rocker Arm End Play
I have the rocker covers off and checked the end play on the rocker arms. Forward cylinder exhaust is .013 and intake is .011. The back cylinder is .007 and .008. The service manual says up to .011 new and replace at .025.I was thinking shimming to .008 would help keepthe front cylinder quiet.
Has anyone shimmed between the arm and support to decrease clearance?SS shims are readily available and purchasing a new arm or support is kind of a hit or miss.
Thanks -- Tom
Thanks -- Tom
RE: Rocker Arm End Play
Thanks for the warning and clarification Doc. Sometimes a good idea has it's risks.That's why I love this forum.Sharing knowledge and experience. I was thinking of using multiple .002 shims to get there. Any thoughts if multiple shims are better than a single thicker one?
Tom
Tom
Well Tom it's the thinshims that tear out of their position by the rocking motion of the rocker. What I do in this situation is buy new cast rocker plates for a tighter fit.....I know this is more spendy for you but to consider what could happen if a torn shim entered the cam compartment and possibly into the oil pump will be major spending. Another solution would be to assemble it with the larger clearances and live with it.
Go to the local dealer and see if they have some take off rocker plates from jobs where they installed the S/E forged plates, you might get just what you need for a song and a dance.
Gunny, the bushing play is right on for all four rockers. It is just the front cylinder end play that's out.
Time to listen to the Doc. That is a very good point about peeling a shim into the case. Time to head down to the dealer. I was contemplating the SE supports, but wasn't sure it would help if the arms are out.
Well checkthe supportsout. They are not real expensive as things go. I just put in some forged SE rocker arm supports and S&S roller tips and they fit very snug. Not too much but cannot **** them to put in. Valve train makes no noise with Woods 7H cam. As Doc said I bet the dealer has some stock ones around from takeoffs.
I just had my dads bike apart putting a set of heads on it, checked the rocker play and tossed around the idea of shimming them. I then thought about the same thing Doc just mentioned and decided I didn't care to pull the rocker box tops each year to make sure the shims were not getting the crap worn out of them because I didn't trust them over the long haul.
