HAS ANYONE USED THE VANCE AND HINE 2 INTO 1 PRO PIPE ON A 110 SCREAMING EAGLE
RE: HAS ANYONE USED THE VANCE AND HINE 2 INTO 1 PRO PIPE ON A 110 SCREAMING EAGLE
only a couple of issues with the 110" cvo bikes...the cams and the lean air/fuel ratio...change those things and you're golden...I have an '08 fxdse2 and it's the best harley I've ever owned...mine has a supertrapp 2 into 1...if you're looking to change exhaust, bassani roadrage, d&d fatcat with quiet baffle, pro pipe hs, and thunderheader are also great 2 into 1 exhausts
hey doc, how you doing?
Doc is correct and i can attest to his statements. The BP version lost almost 10/10 on a mild 107 build is did..The HS is a much better pipe. The baffle can be "tuned" a bit to suit the build as it is removeable on the HS series...No 02 bungs though, they would have to be welded on.
Deshooter
03-19-2008 04:05 PM
