how big before case boring?
RE: how big before case boring?
Donk said it.
After that, say going to a 4" hole, then case boring is required.
Good way to power.
Good way to power.
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
Thanks for the replies!
I have a couple of sets of OE barrels and I was thinking of picking up a SE stroker crank with my extra "stimulius" $ in may, and punching the OE barrels out to the max.
the more I think about it though if your already spliting the cases you might as well to a timken bearing upgrade and make it a 113 ci!
Yep, if you are in there, the 113 at that point doesn't cost much more as the pistons, cyls and headwork is pretty much fixed for most builds. The extra would be the case boring and then any crankwork you may have done. And then, to go to 120, well, just a bigger crank is all
dont forget about getting the crank done by darkhorse. he has some cranks there you can purchase that are already done or he can build one specifically for your application.
getting the crank done and timkin up-grade makes a world of diffrence in smoothness espeacially if your going over the 107 mark.
