Red Engine Light Stays On- Ignition Module
Hey Guys,
I just installed a Screamin eagle 6200 ignition module (for minor engine mod) and matched coil on my 2002 Softail and now the red engine light comes on and stays on when the motor is running. The motor runs great with no missing. Does this trouble code mean a problem or just needs to be reset? Thanks if you have any ideas on what to do.
RE: Red Engine Light Stays On- Ignition Module
Hello Bruce,
Thanks for your quick reply. I scrolled through the codes using the odometer button ( while turning on the ignition at the same time). The reading sequence came up as the folowing: d01clr, d02clr, d03clr, d04clr, d05clr, d06clr, d07clr, d08clr, d09clr, d10clr, then PPU, then #82883, then back to d01clr etc...
I tried to clear any codes by holding down the odometer button for 5 secs. but the red engine light on the 2002 Softail still remains on even though the motor runs great. I agree there should be a simple reset but I don't know how to do it. If you do know how please let me know.
Thanks for your help,
Carter
IF anyone knows the list of codes and what they mean for a 2002 Softail please post. On this forum there is a list for a 2004 RK and how to clear them but they are not the same for a 2002 Softail.
Carter
Im chasing the same type of thing, but on a 99 fxdwg... spent 125 in diagnostics at the local dealer to no avail.... in the mean time I've found this - but I don't see your code..
[i]Be advised this only applies to the full serial data bikes, ie 04 and 05's
The IM (instrument module) is capable of displaying DTC's (diagnostic trouble codes).
Speedometer Self Diagnostics: The speedometer is capable of displaying and clearing speedometer, tachometer, TSM/TSSM and ICM/ECM Diagnostic Trouble Codes (DTC).
1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button. Background lighting sould illuminate, speedometer needle should sweep its full range
and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word “diag” should then appear.
4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with the first P flashing.
5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module)
to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
P = ECM/ICM (Electronic Control Module (EFI) / (Ignition Control Module, 'Carbureted')
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
SP = speedometer
T = tachometer
6 - To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC’s the code will be
displayed or the word “none” will appear if there are no DTC’s. Push the odometer reset button again to view additional codes if they exist.
7 - Record the codes.
8 - If DTC’s are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed.
NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up.
Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC’s again by repeating steps 1 to 9.
If the code is current it will reappear.
9 – Press and release the odometer reset button to continue to the next module.
10 – Turn Ignition switch to OFF.
DTC FAULT CONDITION MODULE
B0563 Battery Voltage High TSM/TSSM
B1004 Fuel Level Sending Unit Low Instruments
B1005 Fuel Level Sending Unit High/Open Instruments
B1006 Accessory Line Overvoltage Instruments
B1007 Ignition Line Overvoltage Instruments
B1008 Reset Switch Closed Instruments
B1131 Alarm Output Low TSM/TSSM
B1132 Alarm Output High TSM/TSSM
B1134 Starter Output High TSM/TSSM
B1135 Accelerometer Fault TSM/TSSM
B1151 Sidecar BAS Low TSM/TSSM
B1152 Sidecar BAS High TSM/TSSM
B1153 Sidecar BAS Out of Range TSM/TSSM
P0106 MAP Sensor Rate of Range Error Carb
P0107 Map Sensor Failed Open/Low Carb
P0107 Map Sensor Open/Low EFI
P0108 Map Sensor Failed High Carb
P0108 Map Sensor High EFI
P0112 IAT Sensor Voltage Low EFI
P0113 IAT Sensor Voltage Open/High EFI
P0117 ET Sensor Voltage Low EFI
P0118 ET Sensor Voltage Open/High EFI
P0122 TP Sensor Open/Low EFI
P0123 TP Sensor High EFI
P0261 Front Injector Open/Low EFI
P0262 Front Injector High EFI
P0263 Rear Injector Open/Low EFI
P0264 Rear Injector High EFI
P0373 CKP Sensor Intermittent Carb
P0373 CKP Sensor Intermittent EFI
P0374 CKP Sensor Not Detected Carb
P0374 CKP Sensor Synch Error EFI
P0501 VSS Low Carb
P0501 VSS Low EFI
P0502 VSS High/Open Carb
P0502 VSS High/Open EFI
P0505 Loss of Idle Sped Control EFI
P0562 Battery Voltage Low Carb
P0562 Battery Voltage Low E
SP = speedometer
T = tachometer
P0501 VSS Low Carb
P0501 VSS Low EFI
Carter, what did you find?
Hello Bruce,
Carter
Carter
Thanks,
Pete
the carbed bikes dont have an ECM like the FI bikes. the ignition control unit that you installed handles that function. what unit did you install? brand? new or used?
ive had some in the past that did not play well with the rest of the bike, post up what unit you used then we can go from there.
sorry just reread what part number unit did you use?
m
m
m
m
Pete.
Holy thread resurrection Batman!!! Even 15 years and some change it's still not a record breaker...had there been no posts in 2006 it would have smashed the previous record. Puts this one around 4th place and there's no prizes for not finishing on the podium. Welcome to forum to the new guy.
Pete B (06-24-2021)
