Hot Shot Motorworks
Hot Shot Motorworks
Has anyone used or herd of Hot Shot Motorworks? I have a 05 Night train EFI and am looking to do a 95 Kit. Hot shots does the 95 kit for roughly 2400. Includes everything. Send them your Cyl & Jugs and they come back completely bored, and cyl come back ported polished and flow tested and all new components installed. You also get the twin tech fuel system. I guess with this you wont need to Dyno tune and use a SERT. Anyone used one?
If anyone has used them before what did you thinkg of Hot Shot MW? http://www.hotshotmotorworks.com/ That is the site if anyone wants to check them out. They say that with the 95" kit running an EFI bike I will see about 102HP and same area on TQ.
RE: Hot Shot Motorworks
Yes I did a build for a customer that already had the Hot Shot heads. The cc's where off by 5cc from one head to the other so I had to mill one head to get the compression even. The valve spring seat pressures where off by 40 lbs for the cam used. The valve guide to valve stem clearances where at the wear limits. After everything was fixed I was able to pull 107/108 SAE out of the 95' build after the tune.
austraco, davidson, engine, exhaust, fabricante, harley, heads, hot, hotshot, hotshotmotorworkscom, motorworks, reviews, shoot, shot, shots
