Crank position sensor
RE: Crank position sensor
The codes for the delphi errors are .. Current 41 CKP sensor intermittent ..Current 41 CKP sensor synch error
The code 41 has no value assigned and when a CKP goes out on you , the engine will either not run or run poorly. Depending how far you have to ride, I would guess you'd be OK to do it,.
ORIGINAL: jb bill
What is the most common reason for the sensor to fail, and is it a common repair?
thanks again
JB bill
thanks again
JB bill
If it isn't a damage problem causing a failure being it is so close to the oil filter and gets some abuse at an oil change, the magnet in the sensor attracts metal filings from the engine oil as does the VSS in the transmission causing it to fail. Cleaning sometimes helps out but is only considered a temporary fix at best. There has been an upgraded snesor put out now that tells me they may have had a problem with the origional in the area of the wiring junction. It is not as common for these to fail as the VSS in the transmission is... https://www.hdforums.com/m_93482/tm.htm
Info here.. CPS upgrade
Well I changed out the crank position sensor last night wasnt too difficult to do but it would have been alot easier if I had another pair of hands to help with the fishing of the wires through the conduit. The idle smoothed out and the trouble code went away.
thanks
JB bill
thanks
JB bill
