Sponsored by: Jekill and Hyde
88 twincam compression ratio?
Old 05-20-2008, 07:09 PM
23champ's Avatar
23champ
23champ is offline
Default RE: 88 twincam compression ratio?
no suggestions?
Old 05-20-2008, 09:30 PM
Colonel Sanders's Avatar
Colonel Sanders
Colonel Sanders is offline
It sucks instead of blows? I'm just speculating but that would sure have me wondering if the cam were somehow installed incorrectly or (since you say it's not) that it was ground incorrectly. Strange. Or....maybe the exhaust valvespring is broken? I take it that cylinder is not firing so perhaps with a broken spring on the exhaust side it's sucking in on the combustion stroke.
Old 05-21-2008, 06:08 AM
BVBOB's Avatar
BVBOB
BVBOB is offline
My guess would be that you still have the cams installed incorrectly, if you think about it though, if the outer gears are correct, the rear cannot be off because of the fact that the front cylinder cam is driven off of the rear, so if the inner cam drive is the problem it would seem as though the front cylinder would be the odd one. Go back in and check the cam to cam alignment, if you have chain drive be sure and check the dots with the tensioner released, I had a bike in once with this problem and I looked at the dots for 15 minutes and would have sworn they were correct, after releasing the tensioner to take the slack out of the chain it was easy to see they were off a tooth, and yes, it had an odd exhaust note, also when examining SERT data log theMAP was around 50 instead of the 35 range like it should have been. Doubt you hurt the valvetrain or you would not have compression, 150 sounds about right for 37's with no other work.
Old 05-22-2008, 03:38 AM
towboattrash34's Avatar
towboattrash34
towboattrash34 is offline
ORIGINAL: mtclassic
The amount you shave off is totally dependant on how big the volume is to start with. If your heads are 89cc's (some are mine were) then you might have to take 40 thou off to get to 83cc. If you are staying 88 you might need to go smaller than 83cc.
you don't have to go smaller... heck i have 89cc heads and 10.5.1 comp w/10.5.1 J&E pistons..... you just have to get the cam you want and have the head porter work from there..he needs to know the lift/duration of the cam and he can sugest the kind of pistons to go with..
[IMG]local://upfiles/43892/15379AAFFFED4E97AE3C4E7781A9718B.jpg[/IMG]
[IMG]local://upfiles/43892/00E944507E234554B6FBB2514F64FAD2.jpg[/IMG]
Old 05-22-2008, 03:48 PM
mtclassic's Avatar
mtclassic
mtclassic is offline
I was basing the head cc volume on stock 88 pistons. He was inquiring about stock compression 88 so I assume he is using stock flat tops.
Old 05-22-2008, 09:14 PM
23champ's Avatar
23champ
23champ is offline
If you hold the throttle at 1/4 turn (in neutral) it seems to stumble every now and then on therear cylinder. Sends a vibration thru bike when it stumbles. Front cylinder never misses a beat. Throttle response seems to be ok.
01HellOnWheels
Engine Mechanical Topics
03-08-2018 08:47 AM
PHA-Q
04-04-2011 03:31 PM
GS357
09-06-2010 07:25 PM
hdFLH68
03-16-2010 06:52 PM
jrtiller57
04-17-2007 09:53 AM
Quick Reply: 88 twincam compression ratio?
