Sponsored by: Jekill and Hyde
WTK: Float Arm Adjustment - Up or Down?
Old 02-27-2006, 01:42 AM
ultravista's Avatar
ultravista
ultravista is offline
Default WTK: Float Arm Adjustment - Up or Down?
Bear with me, I've just spent a few hours soaking up fuel vapors ...
The bike: 2001 EFI Softail Night Train (FXSTBI)
I'm having fuel gauge inaccuracy problems and need to adjust the float arm inside the tank. The fuel gauge sending unit and arm are somewhat "Z" shaped as depicted in the 2001 shop manual. I get about 130 miles before the tank reads empty, after topping off. The gauge itself does work, reads full and drops as the fuel is consumed.
Here's where I've gone stupid.
My low fuel lamp is lit and the gauge is below E but there's approximately 2 gallons of fuel in the tank. I know as it was siphoned out and put back in. This tells me that the float needs to be adjusted but for the love of God, I can't tell if it needs to go UP or DOWN. I would assume that bending it DOWN would lower it into the fuel further, raising the "float" resulting in a higher reading on the gauge.
If it were that easy. I've bent the rod both ways and haven't gotten any further in changing the gauge reading.
So, which way should I be bending the arm, UP to raise the float or DOWN to submerse it further?
Also, what would a bad or faulty fuel gauge sending unit do?
For what it's worth. It must have been this way for a long time. The previous owner told me the tank was 3.5 gallons. I knew better. Funny thing is that it takes about 3.2 gallons to top it off when the gauge reads empty. This tells me it's been way off for a long time.
Thanks in advance.
Old 02-27-2006, 02:17 AM
wa state rider's Avatar
wa state rider
wa state rider is offline
Default RE: WTK: Float Arm Adjustment - Up or Down?
It needs to go down as it says empty when there is fuel in the tank. Should say empty when tank is empty. It could be the sender itself though, not the float level in which case moving the float won't remedy the situation.
Old 02-27-2006, 02:21 AM
wa state rider
PS You have a great looking scoot.
Old 02-27-2006, 11:26 AM
ultravista's Avatar
ultravista
Thanks for the compliment. Been doing a lot of work in the bike and it looks pretty different. New pipes, mirrors, lighting ...
I'm going to price the fuel gauge sending unit today. It's pretty small so it should not be that expensive. While I'm at it, I may just get a new float arm.
Old 03-01-2006, 01:57 AM
wa state rider
HD stands for hundred dollars you know
ORIGINAL: ultravista
Old 03-01-2006, 12:46 PM
fxstcguy98's Avatar
fxstcguy98
fxstcguy98 is offline
Man you have been sniffing gas fumes, a Harley part, cheap? They charge $4 for a stinking bolt.
Old 03-02-2006, 11:23 AM
ultravista's Avatar
ultravista
Thanks for the feedback. It wasn't that difficult, even though I was high on gas fumes ...
I measured the fuel going into the tank at exactly 2.5 gallons and adjusted the needle for 1/2 tank. When done, I topped it off with 2.25 gallons, threw some wax on the tank and called it a job done.
The only thing that puzzles me is how it got this way in the first place. My float arm is "Z" shaped and was not all that easy to compress. Being off by more than 2 gallons from the factory is what bothers me.
Neil
06-09-2013 09:29 PM
FireFighter25
05-17-2011 01:37 PM
karlmdog
03-19-2010 11:56 PM
gedo76
03-03-2009 04:16 PM
dhutchison
07-15-2006 01:57 AM
Quick Reply: WTK: Float Arm Adjustment - Up or Down?
