Cam chain tensioner replacement
Does anyone have an easy instruction setup for installing cam chain tensioners for a 05 wideglide? Dealer wants $815 to change to gear driven and $515 for changing just tensioners, I find that to much for my budget right now. Looking for easy to do cam tensioner install, saw the one on DIY forum and I don't want to cut anything just change and ride. Any help would be appreciated
RE: Cam chain tensioner replacement
Did mine with a wrench friend and it took about 3 hrs. Considering what all is involved like special toools ie. grenade pins and what might really give you some problems ie. exhaust bolts and the cost of new tensionors $515 really doesn't sound that bad.
ORIGINAL: njesus
Tools, http://www.georges-garage.com/Engine_Tools.htm #320500 $24.95 plus shipping. 2 tensioners inner and outer like 60.00 each. Gasket, less then $10.00. exhaust seals if needed $10.00 Small I-let snap-ring pliers from Harbor Freight (since you will only need them once) $6.95 I would do the cam bearing while you are there if it has more than 50K but that is another $75 in tools and $40 in parts.
I did miss 2 tools (inner cam bearing puller and pump alignment pins) and if you know your way around a press the cam shaft remover and installer should not be needed. The entire install kit HD #17045-99C has all the parts you will need except the tensioners. I think it is like $67.00. The service manual shows using the wireform from a binder clip. It actually works. Replacing the push rods with HD #18404-08 will make the job a whole lot easier. Than you won't need to pull the rockers. If you are serious about doing this I would inspect the cams and lifter rollers and camplate where the pump gears ride closely. Good luck.
2002, cam, chain, change, changing, davidson, diy, exhaust, harley, note, replacement, tensioner, tensioners, tentioners, tesioner
