Sponsored by: Jekill and Hyde
Keihin CVK 40 27492-96 Carb spit, spit, choke sputter
Old 08-12-2008, 07:35 PM
tootal's Avatar
tootal
tootal is offline
No, I'm afraid this is a constant, they just sell needles. It would be best if you drilled it in a lathe or better yet use a reamer. You might check your local machine shop and see if they can do it for you.
Old 08-13-2008, 04:40 AM
madcritter's Avatar
madcritter
madcritter is offline
My old slide was plastic with a couple of holes other than the needle hole in it. The new one I got the other day that I drilled out only had the one hole other than needle hole wonder why and whats the difference ??
Old 08-13-2008, 08:46 AM
kansasroadking's Avatar
kansasroadking
kansasroadking is offline
that sounds like a DJ thunderslide kit has been installed at one time or another...
did you use the slide spring that was in with the plastic slide? if so, it won't work with your new slide very good, what needle do you have?
it's a 80" Evo right? I would put EVERYTHING back to STOCK; Needle, UN-DRILLED slide, (I think you screwed up by drilling it) slide spring, emulsion tube, genuine Keihin jets, (45 slo,185 main) and make sure the needle jet (on top of the E-tube) is not upside down, very easy to do.
then make sure the float height is correct, 2 turns out on the mix screw and I'd bet you would be very close, as long as there are no intake leaks....
my set-up is; stock (un-drilled) slide & spring, N8EA needle w/1 shim, 48 slo, 195 main, 2 turns on mix screw. this is on a '06 95" twincam, with cams, K&N, pipes, zippers ign., etc.
I have no coughing, backfiring, etc. etc. I gave it what it seemed to want and it runs very good.....
Old 04-18-2012, 08:13 PM
pjsnighttrain's Avatar
pjsnighttrain
pjsnighttrain is offline
2nd Gear
i thank that your neddle seat is in upside down
Old 07-24-2020, 11:02 AM
Gary Lee Hope's Avatar
Gary Lee Hope
Gary Lee Hope is offline
Stage II
Have had this 92 ultra classic tour glide with Keihin CVK 40 27492-96 Carb for several years. Love the bike, never lets me down. But when cold or at some stop lights it spits back through the carb, a real pain in the butt. I was going to replace the carb with an S&S E or a Mikuni but neither would work with the cruse control which comes in nice on the long rides. So ordered a stage 1 upgrade from Johns Motor Cycle parts and the EZ-Just mixture screw. Put them in today and have to finish re installing the carb in the morning. The bike has the Screaming Eagle Ignition Mod, K&N breather and modified stock mufflers. When doing the install today I noticed that there was burnt/black area in the Upper slide chamber area (from the popping back). when I changed out the pilot jet it had a # 48 in it I replaced it with a #46 the Main jet was a 185 which I replaced with the new one of the same size. Any ideas or suggetions, I'm all ears ??
What altitude are you using that bike generally ?
Old 07-24-2020, 11:04 AM
Gary Lee Hope
Stage II
What altitude are you riding this bike mostly ?
Old 08-02-2020, 06:54 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 8,499 Likes on 4,612 Posts
This thread is 12 years old.
The guy you are asking has not been on the forum since 2011...
BobbyH83
11-26-2017 08:31 AM
Zenmoto
Carburetor Related
02-11-2017 08:18 AM
qcbowhunter
EVO
01-31-2017 09:49 PM
The1stman
Carburetor Related
15
04-10-2015 08:08 PM
bryon857
Ironhead
02-21-2008 06:56 PM
Quick Reply: Keihin CVK 40 27492-96 Carb spit, spit, choke sputter
