Sponsored by: Jekill and Hyde
Woods TW-408-44 Cams
Old 09-29-2008, 07:42 AM
skulznflames's Avatar
skulznflames
skulznflames is offline
Default Woods TW-408-44 Cams
Anyone using these cams yet on their 96 or 103, 107 builds ?.
Keen to hear how they compare to the likes of the Woods 6, Andrews 54, S&S 510.
Old 09-29-2008, 04:09 PM
drhooligan's Avatar
drhooligan
drhooligan is offline
Are these the new Woods cams?
Old 09-29-2008, 07:13 PM
chad peterson's Avatar
chad peterson
chad peterson is offline
They're not new, but newer. Almost identicle to the 400's, lift is the same, but the intake closes a little later on the 408's. Closes at 44 as opposed to 42 with the 400's, and the duration is longer at 248 as opposed to 244. Very little difference. I ran the 400's in my 95" for a while, really liked the power band with incredible torque hittin down low! On the down side the ramps are very aggressive and made alot of noise, so I ended up going with the cams I've got now (t-man 590's). Pretty much the same power while not pushing it with the high lift.
Old 09-29-2008, 08:20 PM
skyhook's Avatar
skyhook
skyhook is offline
they look great to me...I predict they'll be as good for 103" as the wood 6 is for 95"
Old 09-29-2008, 08:55 PM
Old Gunny's Avatar
Old Gunny
Old Gunny is offline
I have the woods 7H. Almost the same intake duration (40) lower lift, 0.575, I think. Wonderful cam.
Setup with springs for the 400 and I guess the newer 408 also.
Per Donnie Petterson in AIM Mag, I adjuster the Fueling lifters 4.5 turns down instead of 3.0. No noise anymore. Targets 0.05 for lifter adjustment instead of 0.10.Made a wonderful difference.
Old 09-30-2008, 12:03 AM
splitting_lanes's Avatar
splitting_lanes
splitting_lanes is offline
The 408-44 cams are new for the 07 and up motors. They have a 248 degree duration and a 530 lift, and are rated to work with stock springs - a bolt-in cam.
I'd expect they'd be like the Wood 6, except the torque curve would be centered higher... a little less bottom end, a little more top, and a little bigger peak. I'd ask Bob Wood what he thinks would be best for your riding style, he's more than happy to help customers.
Old 09-30-2008, 04:55 AM
skulznflames
This is an extract of an email I sent to Bob Woods and his reply:
I am after a cam that will do a bit of everything I suppose. (if there is such a thing). I really love to ride the bike hard for relatively short distances at times (bar hopping I think is the term you guys use) and at other times I need the bike to behave for highway riding. I definately am not the type that just cruises around. I have no care for fuel consumption savings.
Bob's answer was as follows:
You are in luck. Go to our web & check out the new TW408-44 bolt in Knight Prowler cam for your bike. Chain drive & no head work.
Call Bob Wood 205-525-4949 for more details.
Thanks
Bob Wood
Old 09-30-2008, 03:26 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
The 6, 6H, 7H, 400, 408, and 44 Magnum are all ground from same centerline.
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Old 09-30-2008, 10:01 PM
BVBOB's Avatar
BVBOB
BVBOB is offline
One thing I must add that I never see brought up much in the discssion of wood cams is their excellent low speed manners and driveablility, even when compression is not pushed to the max.
Old 10-01-2008, 06:30 AM
Hillsidecycle.com
Sponsor
News Flash!
Have a client coming in from eastern Upstate N.Y., to build an 2009 next week.
107" drop on, D&D Fatcat, our in-house Stage II Heads and the "44 Magnum" cam.
Really looking forward to this!( I'll bet our client is too!)
I'll be sure to alert you folks to the outcome.
Quick Reply: Woods TW-408-44 Cams
