GMR 98" questions
GMR 98" questions
i am thinking of getting a gmr 98 this winter, i was going to do a 95" kit with headwork but this seems to be a better setup for about $1000 more, i was wondering for those of you that have them, what kinds of numbers did you make and what exhaust are you running, also what are your overall impressions of the kit, as far as reliability goes, any problems? how many miles have you put on? any input would be greatly appreciated
I have a HQ 95 that has #s the same as the last poster, I would rather save the 1K, or put it toward a 6speed trans!
Jason
If your having piston slap, then it sounds like you didnt gap your rings corrently, check the piston to cylinder wall clearance through the entire STROKE, or you didnt break em in properly but most likely its some combination of the 3 potential issues just mentioned.
The Nikasil cylinders are far superior to the old style iron lined cylinders if setup and installed CORRECTLY.
Most people dont realise that the nikasil lined aluminum cylinders and forged piston setup need much tighter piston to wall clearance since expansion characteristics are very similiar. Most people setup tolerances based on an iron lined cylinder wall and this is WRONG!
My 98" setup doesnt burn or consume a drop of oil, nor do my pistons "slap".
One bit of advice though, dont go through GMR, go through NRHS performance. This is a real deal shop and they sell superior Axtell nikasil cylinders. Not the "Millenium/revolution performance" crap that GMR has pushed in the past............
if you went with Baisley super stock heads , tw6 cam and 95 in cylinders and pistons you will be over 100/100.
now the only way to get some real power out of a a 98in kit is to go thu axtell or nrhs.
cyl and pistons.
or have some one bore your stock cylinders to 98in.
hyper performace or hillside does this and stand behind their work as others dont thats a fact...
imo 95 in , baisley heads , 6 cam .030 hg 10.0 compression will make you a very happy guy.
want more power alls ya got to do is up the compression and go to a tw6hg cam and it will rock. been where you are thinking dont do it....
cyl and pistons.
Nikasil cylinders cannot be machined by the engine builder. Stock cylinders can be bored to 98" precisely and the pistons selected to match. IMO, the cost difference for the nikasil doesn't justify whatever advantage, if any, they have over stock cylinders.
Good luck with your research and project.
Take a look at Head-Quarters also. You can spec and price your build on their website:
http://www.head-quarters-usa.com/ushome.html
have to agree with most that the nickasil is a little shady, jaguar used this technique for a while in there sadans and the engines would burn oil like crazy after a short while, speculate the coating is very hard and rings don't like to seat in well. i like the cast iron because it's much more stable, ever talk to anyone about how much these aluminum engines grow when they get hot? wonder how much distortion happens when you get a set of millenium cylinders good and hot? i'll stick with my axtell 4.125 iron cylinders.
