Sponsored by: Jekill and Hyde
96" jugs on a 88"
Old 10-02-2008, 10:02 PM
wrenchguy24's Avatar
wrenchguy24
wrenchguy24 is offline
Default 96" jugs on a 88"
Is it possible to put the 96 inch jugs on a 88 inch to make it big bore??
Old 10-02-2008, 10:22 PM
BVBOB's Avatar
BVBOB
BVBOB is offline
96 and 88 jugs are the same, the bigger cubes comes from the longer stroke of the 96
Old 10-03-2008, 03:34 PM
bazam9s's Avatar
bazam9s
bazam9s is offline
wrenchguy24, I'm not trying to hijack the thread but BVBOB's answer was also something I was trying to understand while contemplating a 95" Build.
My question is, is compression decided on type of headwork or piston type, or a combination of both. I am thinking I want to go to 10.1 or 10.25-1 and want to learn how I get there.
Thx
Old 10-03-2008, 05:09 PM
stevelacy's Avatar
stevelacy
stevelacy is offline
compression ratio is a combo of both. to nail it to a specific number you need a list of data, piston compression highth, head gasket thickness, head chamber cc. tons of different products out there. i use the 10.5 s&s piston in my 95 with a stock head chamber size unaltered. and a .030 cometic head gasket.
don't spend a bunch of money on 96" cylinders as your cylinders are the same, you can have yours bored for 150 maybe 200bux. maybe less?
Old 10-03-2008, 05:55 PM
bigoscycles's Avatar
bigoscycles
bigoscycles is offline
Cylinders are the same, stroke is different. Compression is made up of both and then some.
Old 10-03-2008, 06:51 PM
mtclassic's Avatar
mtclassic
mtclassic is offline
compression is made up of bore, stroke, piston deck height, head volume, piston dome volume, head gasket thickness. Do a google search of compression calculators and you will find all you need to know.
Old 10-03-2008, 08:05 PM
bazam9s's Avatar
bazam9s
bazam9s is offline
Thx for the reply's..Steve, I found a pair of Harley 95" BB jugs silver (EGS color) HD 16549-99 brand new in box on ebay for 180.00. I think it's a good deal. But on Chicago Harley site it states the bore is 3.875. Is that a standard bore for a 95"? will I be able to find pistons that match?
Old 10-03-2008, 10:26 PM
wrenchguy24
Thats what I was wondering also !!!!
So they are allready 3.875 ????
Old 10-03-2008, 10:47 PM
bazam9s's Avatar
bazam9s
bazam9s is offline
yeah, I even googled the part number and it came up with 3.875.
Old 10-03-2008, 11:49 PM
kansasroadking's Avatar
kansasroadking
kansasroadking is offline
Yes, the new jugs are bored to 3.875, which is standard bore size for 95", but used seasoned jugs hold their roundness better when bored out.
when you have somebody bore your 88" jugs and buy pistons from them, they bore and hone the cylinders to custom fit the pistons that are going in them, not off the shelf pistons that *should* fit properly, if you are trying to save a couple hundred bucks, go ahead, it will run ok, maybe even pretty good, but I'll spank your *** with my custom fitted and matched components every time... it makes a difference for not much more coin..... (-;
Quick Reply: 96" jugs on a 88"
