SE MCR Perf Heads?
SE MCR Perf Heads?
I have a chance to get these heads failry cheap, new. I plan on a 95" build this winter. Wanted to know if anyone used these or knows about them?
My other option was to send my heads out for cc/porting/springs/cr. Looks like these are all set up?
I'm really not stuck on SE..but for the cost of getting my heads reworked they looked like a good deal complete...My tune of choice is the T-max and I planned on Andrews 37G for my cam. I'm shooting for 10.5:1 with SE Flat tops...
SCREAMIN’ EAGLEŽ PRO TWIN CAM MCR
PERFORMANCE CYLINDER HEADS-16953-08
We’ve combined the proven Screamin’ Eagle valve train
components and innovative port shapes from our EvolutionŽ
1340 cylinder heads with the Twin Cam engine “bathtub”
combustion chamber with a volume of 76cc’s to create a
cylinder head that really performs. Valve spring can accommodate
up to .575" valve lift camshaft kits and up to 6500
RPM. Heads are machined to accept Mechanical Compression
Release P/N 32076-04.
Anyway assuming these are new that is a great deal and they should work relatively well together and you should get some good low to midrange power from the setup which Im sure is what you want.
tweaked02
09-12-2017 05:00 AM
