Question for 2007 and later high milage motors
I posted this in the touring forums also because they tend to really run a lot of miles
I have been reading "Donny Petersen's Unauthorized Technical Guide to Harley Davidson 1936-Present the twin Cam" In the second book of this series he really puts a lot of emphasis on possible wear or "ovaling" of the rear outboard cam bearing. This is in fact a "Parent Material Bearing" which he feels is an area that TC96 owners should be watching. My question is, have any of you 2007 or later TC96 owners, who consider themselves to have high milage on their engines, had any difficulties with the cam support plate? Also report what type of Oil you are using. Just curious.
But I agree with Donny. You should be aware of that. Have your bike shop you go to or your self check it out. Take it apart if you have conserns and see for your self.
I hope this helps,
I was just wondering if anyone had really had any problems.
I almost forgot, It is the rear cam bearing that caused all of the problems with the 1999-2000 early twin cams. Proportedly from the same condition. It seems that the original Ball bearing design could not stand the very same forces that he is concerned about. However the front bearing being driven only by the chain from the rear cam is not subjected to the same forces.
That is primarily his focus is. This second volume in the series is "Performancing the Twin Cam" However, he does not restrict his concern for just higher performance motors. Donny feels we all need to keep a weather eye out for undue wear.
Well folks, just so ya know, the auto manufacturers have been using "parent metal" bearings on their overhead camshaft engines for many years. With NO problems. As long as there is a constant oil supply to the cam journal, there will not be a failure. That is one reason the newer HD's have a higher volume oil pump, and idle faster, than before. I've got 65K miles on my '03 with a big bore kit and cams and I have 35K miles on my '07. Absolutely no problems with either bike. There is a lot of difference between a theory and practical application. I run HD dino oil in the '03 and HD Syn3 in the '07.
cromagnon
02-22-2011 06:49 AM
N-gin
Exhaust System Topics
34
08-30-2010 06:42 PM
