Twincam 88 Expectations
OK. So I did the requried air cleaner, pipe changes and SERT. Dynoed at 69hp and 73ft-lbs. So I take a look at some of the numbers here http://www.nightrider.com/biketech/hplist_twin_cam.htm for comparable figures and I see that some bikes with similar configurations are pulling more torque with stock pipes.
What can you possibly get out of an 88 without doing major work? I'd consider anything that requires pistons/cylinders or splitting the cases major work. Heads, cams and intake work is fine. Split the cases and my wife will know it's not just routine maintenance. Take the head off - hey, it's just routine cleaning. Cams - just part of an oil change...
Oh, I'm still happy with what I've done. It's just that you can never be too happy - though I'd like to try to get there under the radar.
-DO
-DO
RE: Twincam 88 Expectations
I agree, the pipes are hurting you. Go back to stock head pipes and some good slip ons. Or, if you have the dough, a good set of 2-1's, like Supertrapp.
If you're going to get any power, you need to change cams.
There's no replacement for displacement. You can't beat cubes. Once the heads are off, it's a pretty simple matter to change the pistons and cylinders. And not that expensive. Bore out the stock cylinders, and add cast flat top pistons.
Thanks bob and cladbal,
I probably won't swap out the pipes. I like the look too much to go back to the factory pipes. I have a ProPipe on my other bike and it works great. I don't happen to like the look on a Fatboy.
I guess I'll have to do the cams, pistons and cylinders later. Then again, my wife does want me to swap out the zinc hardware with polished stainless. I guess I could say that the old cylinders don't match the new hardware...
-DO
-DO
After you get done paahking the caah in Haahvad Yaahd, sorry couldn't resist saw you're from Mass, you should search the forums for people with your same parts setup. I think I've seen some SERTS, with V&H, and a SE A/C get near 79/79. Above poster probably right about adding back some good Screamin' Eagles. Still if it's an improvement over stock performance and you like the look then ride on. Maybe you could find a different and better performing baffle for those BSS.
Thanks. I'm not sure if I go back to the standard baffles that I'll get much. I have heard that some have noticed changes between the quiet and standard baffles. But you're right, if I like the look and sound, live with it.
Fortunately, I'm originally from Minnesota so I've got the midwest/scandanavian inflection instead of that rediculous Boston twang...
-DO
-DO
