TC88 Heads vs TC96 Heads
I have a set of TC88 heads that I had 1.94 intake and 1.65 exhaust valves installed, plus guides, springs for up to .700 lift, cm retainers,combustion area polished and cc'd as well as ported intake and exhaust runners. They made good hp (111) and tq (113) on a build that I did on a Wide Glide. I removed them and had another set done with 2" intakes, made more hp (113) and tq (116).
I have a 2008 Street Glide that I am going to build a TC103. Can the TC 88 heads be used on a TC96 engine?
allaco (09-14-2021)
The ported heads are from a 2002 carbureted engine. My 2008 has fuel injection. Do I need a intake for the 02 fuel inj. ? or will my intake work from my 08?
Thanks for the correction, SEDELUXE
The earlier heads have the boss but it is not drilled and tapped so no, stock heads from 07 and back will not actually fit on an 08.
The intakes are intrchangeable through all years, but the 06 and up have a different bolt pattern soif using pre 06 heads, you just have to change the flanges, same if using 06 and later heads with a pre 06 throttle body, just change the flanges.
