103"/oil cooler
103"/oil cooler
Having a 103 upgrade on my 2008 fatty like the thought of the Harley Oil cooler but is there any need ? Yes I know cooler oil is a good thing but dont want to fit it if the engine is fine without.
a, Does not look great,
b, Cost
c, Added weight although minimal.
Just like opinons from you guys that are running hopped up engines
Regards
b, Cost
Regards
I agree, you need a cooler on that bike. In my humble opinion. There is only 1, and that is a JAGG 10 row turbulated oil cooler. It fits on the frame down tube. The Harley one is ok, but it is only an 8 row . The JAGG cools the oil prior to reaching the oil filter, the HD after the filter. Therfore you have a much better flow resistence with the JAGG. Also the JAGG is black powder coated for better heat dissapation than a chrome cooler. Trust me on this one, go with the JAGG. You will get used to the way it looks. I will also add miles to your engine life.
Stroker
Stroker
I don't agree on the "need" of a cooler on a mild 103". Dealer sales ploy.
We too, use the Jagg, frame-leg mounted 10 row units, on builds that require.
They work very well.
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
HD parts are great but not always the best. Have a look at Jagg (by Setrab) oil coolers -- they have low mounts and side mounts which might suit your requirements.
b, Cost
Thanks guys I sort of knew there would be a differing answers.
Any dealer based techs ? Do most fit or not?
Its about $400 fitted here cheap if it saves the engine but just not sure its required
I have had a couple of EVOs with hop ups and no cooler no prob .To be honest I will never do more than 20,000 miles over the next 5 years but we do ride hard when we tour Europe in the heat of Spain etc
Regards
Thanks
Regards
Thanks
your tuning will also have a effect on heat, as well as head porting.
a ported head and a good tune will run cooler that the engine you have now.
I have yet to go over 210 on my oil temps in 4 years and I have a lighter bike, but the fact is, I dont real need one, so Im not going to run one.
high quailty oils have a small say hear too, Ive run Amsoil, and Mobile 1, RP and the bike always runs cool.
My SE Fat Boy comes with the 103" engine. I don't have an oil cooler and have no problems, down here in hot SW Florida. Most heat problems occur while the bike isn't moving or in very slow stop and go traffic. An oil cooler wont help in those conditions, unless you have an electric fan blowing air across it.
Tom
Tom
