Fuel Leaking quick Disconnect
Replace the o-ring and put some lube on it when reinstalling it...
I discovered mine leaking today at the quick disconnect.
My Harley Dealer told me they can't replace the o-ring indavidually....that I would have to replace the entire quick disconnect fitting. $150 plus tax....ouch!!
1) How did you guys dig out the old o-ring without tearing it up? Does it come out pretty easily?
2) Where did you find the correct replacement o-ring? I imagine the inside and outside diameter of this replacement has to be an exact match to the original one. I know I can probably buy o-rings at any auto parts store...so I guess my main goal will be to get the old one out without tearing it up. Any advise would be greatly appreciated.
Finding o-rings at local hardware stores and discount houses can be a challenge. Most of the ones Harley uses are metric. They try and find the most impossible, or foreign-made product so there is no way a person can make his/her own repairs. They can get the repeat business and call the shots on what you can and can't purchase.
I have little experience with the post MM systems, but have posted ways to make fixes to the pre-00 EFI connections in a manner that takes the stealership out of the loop. The problem with the o-rings is that a metric size may be very close to an SAE size "to the eye", but the SAE size will not work. A 5/8 x 2mm (just for an instance) is very close to a 15.8mm x 2mm....but it is slightly larger enough not to work in the intended application.
I have found a site that may be able to sell the individual o-rings. Try bikebandit.com. and navigate your way to your model. They have all the diagrams and can point you to the exact part...and likely the correct o-ring. If the dealer will only sell you the "kit" and not just the o-rings, you may have to resort to that, or try bikebandit. I have made it a point to always have at least one set of o-rings that will fit any fuel related o-ring on my rides.
Bikebandit sells under their particular part number, but when you get the product, it usually has the HD part number on the package also. I am not advertising for bikebandit. It's just that is the only site I have found in which you can do some detailed research and will always get an HD part...no matter what PN: they call it.
If you do a search, this problem has come up before ( I had this problem also). in one of the threads, a part number is given for a Harley o-ring meant for something else that will work. I used it myself and I believe DAWG was the one who gave me the part number. It has been in place for over a year now and no leaks. If I could remember the part number I would just give it to you, beccause I HATE when I ask a question and I get someone replying "do a search", but unfortunately right now, i cant help. I will look back at some old notes and see if I can find it.
