R&R 113" SE Build - Nearing completion.
Sent my cases to R&R last month and ordered up a new 5-Piece Billet Crank for a 113" SE build I had planned. I got the cases back a couple weeks ago and just finished putting together a new 113" for the 09 SG. The build list is noted in my signature and we assembled the new motor at a buddies shop last weekend. With the motor assembled, last night we set it to get it into the bike and tonight we'll complete the peripherals to button it up and get it fired. Here's a couple pictures of the progress to date. Should make some good power when it's all done and said. Dyno will be posted in a couple weeks when I get a tune on it.
Ftf
My builder had talked me into using R&R's FTF crank but was not aware of the bearing installation requirement so in order to save me time, we went with a SE crank welded and balanced by Falicon.
I'll be watching for your dyno numbers to compare to my 113's build numbers which is all SE stage IV stuff (MVA heads, 10.5 pistons, SE260 cam) with a Boarzilla exhaust and SE heavy breather.
