Help with my CV carb
I have a 2006 Softail Standard with a CV carb. I just put a D&M spike air cleaner on my bike and it sputters in full throttle. So I went to change the main jet and my slow jet. When I took the bottom bowl off my carb there was a 180 main jet but no slow jet. The only thing that is there is a brass hole. could any one help me as in what to do?
Is there supposed to be a slow jet there?
I bought a 48 slow jet and there is no place to put it.
Any help would be greatly appreciated.
http://www.nightrider.com/biketech/h...s.htm#slow_jet
Go to this link. The slow speed jet is up inside a tube and you need to get at it with a skinny flat screwdriver. The diagram in the link shows where it is located. I can't believe it would be running very well if there was no jet in there. Let me know if this helps.
We modified an S&K small flat blade almost 20 years ago for this.
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
Look way down the brass tube and you should see a slot for a screwdriver. Its in there a ways. Depending on your bike, 48 may be a little fat. Try it. If you end up 7/8ths to 1.5 turns out on the mixture screw, its good. If you ens up tighter than 7/8ths, go to a 46. The 46 with a Bobby Wood KT-1 needle runs real good. I ran that combo for a while with great results, then I got my carb worked by Dakota Kid and haven't looked back.
that tube next to the main jet with the brass plug is not the slow jet hole. it is the tube that runs along side the main jet tube. The slow jet is up about an inch or so.
