Sponsored by: Jekill and Hyde
Loctite flange nuts to cylinder studs?
Old 04-29-2009, 10:06 AM
CDNbronc's Avatar
CDNbronc
CDNbronc is offline
1st Gear
Default Loctite flange nuts to cylinder studs?
Should I be using Loctite on the flange nuts or cylinder studs when installing a new exhaust system on a 08 FXDC? How do you keep these flange nuts tight? After the install everything looked pretty good but after riding it around I thought the exhaust was leaking and I noticed that the flange nuts were loose. Any suggestions?
Old 04-29-2009, 05:06 PM
Old Gunny's Avatar
Old Gunny
Old Gunny is offline
You can go to a hardware store or better a industrial fasthener store and get 4 swedged grade 8 nuts to fit.
Old 04-29-2009, 05:11 PM
tombeving's Avatar
tombeving
tombeving is offline
Because of the high heat, I'm not sure loctite will help.
Old 04-29-2009, 06:48 PM
mtclassic's Avatar
mtclassic
mtclassic is offline
use anitisieze and check them every ride for a while. DO not use lock tight on the exhaust studs. It is common for them to loosen up a time or two after replacing the exhuasts. Do not over torq as it is a pain to try and remove a broken stud.
Old 04-29-2009, 08:56 PM
mtnlvr's Avatar
mtnlvr
mtnlvr is offline
No loctite, anti-seize as mentioned. Another trick is to put a second nut on the stud to use as a jam nut, but that's tough to do properly on some of those studs. The only issue with the swaged or prevailing torque lock-nut is that the torque values are affected some unknown amount.
jordanball33
03-04-2022 07:20 AM
FLYING_BURRITO_BROTHER
06-25-2014 03:39 PM
nasoscia
Shovelhead
07-28-2009 01:21 PM
cweiss
02-15-2009 12:36 PM
anubisss
08-24-2006 05:09 PM
Quick Reply: Loctite flange nuts to cylinder studs?
