Sponsored by: Jekill and Hyde
carbed twin cam 'coughing' question
Old 06-26-2009, 11:35 PM
Mk1Racer's Avatar
Mk1Racer
Mk1Racer is offline
Default carbed twin cam 'coughing' question
Ok, I was having a problem w/ my '04 WG where the engine would 'cough' back through the carb when it was cold, or if I was cruising along with very little throttle. Spoke to an indy shop about it, as well as a couple of Harley guys, and the suggestion was that it was leaky intake seals. So, I pick up a new carb/intake gasket as well as a pair of intake seals. Spent a couple of hours this evening doing the change. The seal on the front cylinder was definitely leaking, so I'm thinking, "OK, this is the right thing to do". Get it all buttoned back up, fire it up, and adjust the idle. Everything seems fine, and it for sure seems to be running better. So, I go to leave from my buddy's shop for the ride home, and over the course of the 4.5 mile ride, I notice that it's still doing it. Doesn't seem quite as bad, but I'm still getting a cough back through the carb, this time mostly on the low throttle cruising.
Any thoughts? Bike has V&H Straight Shots and a Stage I A/C. I got it like that, and haven't opened up the carb to check the jets yet.
Old 06-27-2009, 01:25 PM
schmeg's Avatar
schmeg
schmeg is offline
Sounds like the slide is coming up too fast. Does it cough when you throttle up, or steady cruising? Drilled slides and thunderslides will do this. Another thought, did the bike sit for a while with fuel in the carb?
Old 06-27-2009, 03:45 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
Keep going up on the pilot jet until it stops.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Old 06-27-2009, 04:29 PM
TXCHOP's Avatar
TXCHOP
TXCHOP is offline
Scott, maybe he needs a whole new top end???
i agree on the pilot jet as well. Scott, you think shimming the needle might help too?
Old 06-27-2009, 04:59 PM
Mk1Racer's Avatar
Mk1Racer
Mk1Racer is offline
Thanks guys, I'll give the pilot jet a try. Sometimes on throttle-up, sometimes just cruising at a very low throttle. I'll pick up a pilot jet when I go get the head washer that I had to order.
Old 06-27-2009, 07:30 PM
Hillsidecycle.com
Sponsor
As Dan said, the needle can be shimmed to expose more of the main jet sooner, and help with throttle response as well.
I don't know about a top end, but maybe,............ a Timken conversion from Maryland???
hehehe.
Old 06-27-2009, 08:19 PM
the blob's Avatar
the blob
the blob is offline
up the pilot jet, then drill the cap out of the mixture screw(too accses it) then back
the mixture screw out a couple of turns. this will solve it. had the same prob on my
sporty + the dyna.
Old 06-27-2009, 09:58 PM
SEDELUXE's Avatar
SEDELUXE
SEDELUXE is offline
hehehe.
dont forget the cure all cam plate and well never mind... you guys are mean just mean.....
please leave you message at the beep....
he aint going to call ya back
Im2cool4u9009
04-17-2019 08:58 PM
Raineman
EVO
13
11-19-2013 08:43 AM
theundeadelvis
EVO
20
10-28-2013 08:32 AM
JohnnyC
Carburetor Related
08-01-2013 06:31 PM
nfe
EVO
04-19-2007 02:46 AM
Quick Reply: carbed twin cam 'coughing' question
