Engine cuts out after filling gas tank
Hi All;
I have a 2001 Fatboy, fuel injected. Whenever I fill the tank up all the way, the engine will cut out within a mile or so. It shuts down for a second or so then comes back on misfires, etc, then after maybe a minute or so of cutting out then coming back on, it will clear up and run fine.
It ony seems to do this when I top the fuel off. If I leave a few inches of space it does not happen.
I recently replaced the fuel filter and hoses inside the tank. Doing this seems to have eliminated the other problem where it started stalling at anything under a quarter tank, but it had no effect on the cutting out when filled to the brim.
It has done this for years and I have just sort of lived with it, but I would really like to understand why this occurs.
Appreciate any feedback.
Pull the cap off, clean it and use the tried and true wrap the mouth around it and suck, don't blow method. You will know right away if its pooched. Wow, just reread your first post. You put up with this for years???
Ron
My CA bike does that too (07 ultra) was told that if you fill all the way up it runs into the smog canister and the canister dont like it. Sorry for the technical description (hehe) but its the nature of the beast. Just back off 50 cents worth or so, dont ask me how I know....
