coughing?
coughing?
My 97 Dyna has a cough, when accelerating, decelerating, doesn't matter. I put in 93 octane gas and that didn't change things. While riding I pulled choke out just a bit, maybe 1/4, the coughing stopped completely. Push choke in and it comes back. What should this be telling me? Obviously something with the carb.
Thanks, Joe
Thanks, Joe
Lean causes cough thru the carb.
Rich causes cough out the pipe.
Your choke is adding fuel, so that kind of confirms the lean symptom.
Might want to go up a lil on your intermediate jet.
Edit: If this is only goin' on when the motor is not fully warmed, I would leave it alone.
A cold motor needs more fuel than a warmed motor.
Bump your pilot jet up 1 size at a time until it quits.
You will also need to adjust your air/idle as well, when doing this.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
Also, it seems that when you are troubleshooting, it is always better to only change ONE thing at a time - so as to better know which "change" actually cured the problem.
OneHarleyAtATime
EVO
45
09-23-2021 07:56 AM
OneHarleyAtATime
Carburetor Related
06-11-2017 05:09 PM
