Sponsored by: Jekill and Hyde
CV Carb Running Rich
Old 07-13-2006, 04:17 PM
ellisem's Avatar
ellisem
ellisem is offline
3rd Gear
Default CV Carb Running Rich
03 Deuce CV carb running rich. Have not made any changes to the bike from when it was running great to now running rich, just slowly began running rich. Same jets, same pipes, same everything. Fouled out the plugs. Took carb apart, cleaned the jets, etc. Replaced the rubber collar on the manifold which had a small tear, but I would think an air leak here would lean it out. Any case replacing it didn't help. Replaced Enrichener cable and enrichener valve as well. Float was a little off so reset that. Nothing has corrected problem. Idle is inconsitent except being very rough. Sometimes high when started, sometimes too low. Idle fuel mixture screw does not seem to cause a reaction even when bottomed out. Gas mileage went from 40+ down to 33, even with new plugs.
Any suggestions/ideas?
Thanks
Old 07-13-2006, 04:50 PM
JohnK/Pa's Avatar
JohnK/Pa
JohnK/Pa is offline
Default RE: CV Carb Running Rich
Does the Deuce have a vacuum line from the carb to the petcock, some Sportys I know have had a rich condition caused by the petcock going bad and fuel coming thru the vacuum line.
Old 07-13-2006, 05:38 PM
HDWRENCH's Avatar
HDWRENCH
HDWRENCH is offline
Is it rich all the time or after you let the bike sit??? If it sits check the needle and seat. Or the petcok is another good thing to look at.
Old 07-13-2006, 05:49 PM
ellisem's Avatar
ellisem
ellisem is offline
3rd Gear
Yeah, it's pretty much rich all the time. It does have a vacuum line that I blew out but didn't check the petcock. It feels like it just isn't getting enough air into the system to lean it out. I even removed the air cleaner thinking it might be restricting air flow, but no effect. I'll investigate the shut off system tonight when I get home.
Thanks guys
Old 04-19-2017, 06:14 AM
Hddjarnis's Avatar
Hddjarnis
Hddjarnis is offline
Stage II
Default Did you solve the problem
Hi. Know this is an old tread. Bur did you solve your carb problem back then?
I have exact same issues.
Regards jan.
harleyrider0249
EVO
14
03-27-2017 07:38 PM
PyroPornStar
04-21-2013 06:57 AM
terrapin88
04-06-2010 11:17 AM
1unclejojo
Shovelhead
07-22-2007 09:55 AM
f6noob
04-20-2007 02:32 AM
Quick Reply: CV Carb Running Rich
