backfire 89 sportster
i have an 89 sportster 1200 when idle/rev breaks up backfires. If the choke is out and idling it dont do it much.
-rebuilt carb,changed plugs,plug wires,choke-check petcok
seems like gas flows little fast when i drained tank/and the overflow line is dripping gas
-before carb rebuild there was extra gas in carb and airfilter
- i am at a loss as to what could be the problem please help !
If choking it helps then it could be an air leak. I'd check that first. Too much fuel in the carb & air cleaner can be a float setting too high. Big cams can also cause this. Look at the carb when it's idling & see if it blows back & forth. This will cause fuel to puddle in the carb & air cleaner. Pulling the choke can stop it. What kind of carb is on it?
