Carb tuning
A vacuum gauge is useful for tuning mult-carb bikes, but I don't see it being much use on a single carb bike. There doesn't seem to be an easy way to tune a carb except with a lot of experience! The book will help, but a novice may not find it easy in practice. That is why top tuners in the past were worth their weight in gold. These days we have machines in the form of dynos that make the job easier and quicker. Having seen my own bike set up on one I would recommend the experience.
46-48 pilot, 175-180 main, air idle 3 turns out.
Good starting point.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
Dude you're getting too cosmic with this. There's only one carb so all you need to do is get it close to optimal AFR's for the style of riding that YOU do. Find a good tuner that will do a few AFR runs for you without screwing you around with all those high rpm hype numbers. Trying to screw around with vaccum readings will only result in a hacked up cv40 and you'll just be buying another slide to replace when your dremel has chopped up this one. If you ride for the enjoyment of riding you can get these things pretty dam close in your garage. If you buy into the high rpm dyno crap you'll be chasing your tail. Tuning depends on what type of riding YOU do, so take all the forum suggestions about tuning with a grain of salt.
Oh,OK.
