Quick Disconnect from Gas Tank
All,
I have a quick question. I disconnected the quick disconnect from the left rear of the gas tank. I disconnected it at the gas tank. When I reconnected it, it sprayed some fuel out but then seemed to seal up. However, as soon as I pressurized the fuel line, fuel started spraying out pretty good. Since I'm pretty sure it's not supposed to do that, I disconnected the fuel valve and looked inside. I found the o-ring inside it had been torn when I reconnected the valve. Does Harley sell just the o-ring, or will I have to buy the whole assembly. Also, can I get away with going to a hardware store to find a replacement o-ring? Or would it be inadequate and not tolerate the fuel?
Thanks,
Braden
Thanks,
Braden
What model/year? Get the parts guy to show you the blow up on the computer and I bet that the o-ring will have PN. You can order the o-ring, by PN, from Zanotti's or any other discount H-D dealer; might want to buy a couple for spares. It may be a bit inconvenient but I hate when dealers treat customers that way. The parts guy is either a ******** or just doesn't want to service the customer. I would order the o-ring and wait just on principa; but that's just me. I will check the PN in my 2005 FXSTD parts manual tonight and see.
