Sponsored by: Jekill and Hyde
just bough 76 shovelhead
Old 08-04-2010, 09:35 PM
76bobber's Avatar
76bobber
76bobber is offline
Default just bough 76 shovelhead
Bought a rigid 76 shovelhead. It starts and runs strong. I dont have the money to do a complete engine/tranny rebuild now, is there any way to clean up the engine without disassembly? I want to remove it off the frame to check out the tranny because it has the "cant find neutral" problem, but would like to stay away from the actual engine if at all possible. Any suggestions?
Old 08-05-2010, 09:44 AM
50panman54's Avatar
50panman54
50panman54 is offline
Stage II
lots of things to do on that shovel to inprove finding neutral before pulling an engine, check the position of the clutch arm tha can be adjusted fore and aft by the adjustmment screw in the center of the clutch basket. Break loose the 9/16 nut and using a straight slot screw driver, adjust 1/2 turn either way and see if it improves. While you are at it, check the pressure plate distance all around to make sure one of the three nuts are not tighter than the other. The nuts have an indent so each half turn the "find home". This amy also improve netural, but if you back off too much the clutch will slip. If you do a little research you can find a neat trick to remove the pressure plate using a big washer and the 9/16 nut mentioned earlier, then you can pull the clutch discs and plates. Clean the friction discs with solvent and then scuff up before reinsertion.......check out shovelhead.us for the best tech answers you can find anywhere on shovels
Old 08-05-2010, 09:57 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
I will add tha Gunk Foamy Engine Brite/high pressure water will "clean up the engine", then you can mask/paint cylinders/lifter blocks, polish the aluminum with Simichrome, or NeverDull.
One thing that really cures the clutch system on those, (that was concieved back in the VL days) is a Rivera Pro-Clutch.
On the clients bikes we have installed those, the reaction is "I should've done this a long time ago".
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Old 08-05-2010, 03:34 PM
76bobber's Avatar
76bobber
76bobber is offline
thank you both for showing me the way on both issues, have something to go on now.
yaoooza, 450 bones! I'll have to put the rivera pro-clutch on the back burner for now.
Old 08-05-2010, 03:53 PM
SURFOR Chop's Avatar
SURFOR Chop
SURFOR Chop is offline
YOU DA MAN ...! No tech tips to offer ... but, congrats on the scoot ...!
Pbajwabb
05-28-2017 01:27 PM
Sand850
EVO
21
12-19-2016 07:17 PM
John Harper
10-12-2012 10:46 AM
lucious
Shovelhead
04-26-2010 07:52 AM
jerseyiron
Shovelhead
05-03-2008 01:10 AM
Quick Reply: just bough 76 shovelhead
