Sponsored by: Jekill and Hyde
Cam Lift on Stock Heads / Valve Springs
Old 08-05-2010, 08:17 AM
XMA's Avatar
XMA
XMA is offline
Default Cam Lift on Stock Heads / Valve Springs
What is the max cam lift you can use with stock heads / valve springs on the 06' and newer heads?
Old 08-05-2010, 09:01 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
.575" LIFT, will slide under, but piston/valve, valve/valve, must be taken into consideration with certain cams.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Old 08-05-2010, 11:09 AM
XMA's Avatar
XMA
XMA is offline
Thanks Scott.
I toying with the following cam options:
If a Woods cam: TW 6-6 or TW 555 or TW 7H
If an Andrews can: 31H or 37H or 54H
Planning on porting and polishing the heads and bumping the compression to around 10:1 with pistons.
Is piston-to-valve or valve-to-valve clearance and issue with any of these cams using the stock valve springs?
Appreciate the info.
Old 08-05-2010, 07:35 PM
Hillsidecycle.com
Sponsor
All of those are plug/play under that behive spring.
The 555 will want about 10.4-5 to get the full potential from that new grind from Bob Wood.
That will be available in/around 8/20 as we have been told.
Scott
olemans85
Engine Mechanical Topics
11
12-24-2015 08:04 AM
Bring The Metal
14
05-14-2015 07:45 AM
doughnuts
09-23-2014 05:59 AM
I CUT 1
07-21-2009 07:26 AM
Hooter1
05-24-2009 11:18 AM
Quick Reply: Cam Lift on Stock Heads / Valve Springs
