whats the difference in 88 ci head & 95 ci head
will 88 ci heads work with 95ci pistons & cylenders ??? i just installed a thunderheader & se 211 cams now question is buld a good set of 88ci heads from stock heads & leave 88inches or buy 10.25.1 1550 pistons & boar stock jugs if i do this can i use the 88 ci heads .
[IMG]local://upfiles/7791/69194CE1F0B140F4AE57B5588CD4B5AF.jpg[/IMG]
RE: whats the difference in 88 ci head & 95 ci head
I have built several 211 cam, stock heads, 1550 SE cast compression pistons and SE slip on muffler combinations that make 101 tq and 92 hp
good headwork will get you higher HP and a longer power band, overflowing the heads will be a dissapointment.
ORIGINAL: XfasteddieX
Prodigal_Sun (03-21-2020)
