Sponsored by: Jekill and Hyde
88 cu.in. to 96 cu.in. Electra Glide
Old 12-01-2010, 02:53 PM
awente@comcast.net's Avatar
awente@comcast.net
awente@comcast.net is offline
4th Gear
Default 88 cu.in. to 96 cu.in. Electra Glide
My son just bought an electra glide with a 88 cu.in. Can't remember if he said 2002 or 2006. I've got a set of 96 cu.in. jugs, pistons and a stock cam. I'm wondering if we can swap them or do we need more. Such as the heads, fuel injection system and different ecu.
Old 12-01-2010, 04:47 PM
djl's Avatar
djl
djl is offline
Received 2,029 Likes on 1,498 Posts
That's a loaded question but I will take a shot.
Jugs will need to be bored; the 96" cylinders are the same bore as the 88" cylinder; the 96" comes from the increase in stroke from 4.0"" to 4.38". So, bore to 3.875" to fit a set of new SE cast flat top pistons.
Don't know why you would want to install the stock 96" cams; I don't know the differences in profile but if you are going to change cams, change to some that will make a difference. Cam selection will depend on riding style and other modifications.
Headwork will always help. Your options run from a BigBoyz "street" port job for $299 toi a set of fully ported Baisley (or other) heads for more than $1000; depends on performance goals and budget. A BigBoyz street port, plus machine work for chamber balance and decking for compression will run about $500 and, IMHO, a great value. If you can get your hands on those 96" heads, you could install them without any headwork and see some gains; they flow much better than the earlier heads.
If you increase displacement, upgrade heads and cams, you will need a fuel mangement system. Your options are Thundermax with, or without, autotune to the TTS Mastertune. You should check in your area for a tuner with a rep for good work and find out what he/she likes to work with. If there is no dyno tuner readily available, the Thundermax may be the way to go as it has an auto tune feature and, from what I read, pretty user friendly. I have no experience with the TMax but everyone I know that has is quite happy with it. The TMax has it's own ECM but others will retain the use of the stock ECM.
You did not mention exhaust or intake. To complete the package, you will need to open up the air intake with the SE air cleaner and convert the exhaust to a good 2:1 exhaust sytem like the V&H Propipe or the Python 3; both are good value and hard to beat for the money.
BTW, the FLHT, particulalry if an '02 is a solid machine with a strong bottom end. H-D cranks were still forged that year and the Timken crank bearing was still in use; boht have been downgraded, IMHO, since that year.
Good luck!
Old 12-01-2010, 05:15 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
No gains to be had with that swap, as djl has pointed out.
BUT, if more power is what your after, your cylinders bored to 3.934" will show what we refer to as 98", using our proprieitary Wiseco piston kit.
That combined with a Wood 6, or better yet, the torque mac-daddy, his 400G, along with a set of our Stage III heads, and it'll show 110-115 hp, and 110-115 ft/lbs.
Great fuel enconomy as well.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Old 12-02-2010, 08:52 AM
awente@comcast.net
4th Gear
Thanks, that information was very helpful.
Old 10-13-2012, 02:14 PM
Sgt_Jim's Avatar
Sgt_Jim
Sgt_Jim is offline
Hey I'm kind of resurrecting this thread because I'm curious about the stroke.. I'm thinking of doing a 107" build this winter, which means I'm going to also have a set of 96" cylinders and pistons laying around.. a buddy of mine has an 02 electra glide standard with a carb'd 88".. are you saying it's not a simple swap-job because of something to do in the bottom end? that the 88" crank in the bottom doesn't have enough push for the 96" cylinders?
Old 10-14-2012, 07:15 AM
lkr0's Avatar
lkr0
lkr0 is offline
you need a larger crank; the jugs are the same size
Old 10-14-2012, 04:14 PM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
Jim, when Harley went from the TC88 to the TC96 they changed the crankshaft, not the cylinders. A TC88 can be bored out to between 95 and 98 ci, depending on who does the conversion. Your cylinders are no use for your buddy, but if he wants to tune his bike show him Scott's reply above.
Old 10-14-2012, 04:44 PM
Sgt_Jim's Avatar
Sgt_Jim
Sgt_Jim is offline
okay, cool thanks for the reply
Butts05Train
03-12-2020 08:49 PM
REW13
Engine Mechanical Topics
03-20-2019 03:48 PM
02 softail
01-09-2014 02:59 PM
04 rkcrr
28
01-29-2012 07:50 PM
mikestreet
12-09-2008 07:42 PM
Quick Reply: 88 cu.in. to 96 cu.in. Electra Glide
