ev27 upgrade question!
i have a 1990 softail custom with a stock L grind camshaft. I have a andrews ev27 that i was going to install but i have heard that its not worth upgrading as the stock L grind is very similar to the ev27. So what im asking for is your opinions if i should put in the ev27 or keep the L grind in there?
Depends what you want...The L has no overlap..very smooth running cam..The 27 has a much nicer idle, however they can be noisy ..tic tic tic..As far as power I doubt you would see much difference.I have changed 3 cams in a weekend to decide which one I liked best..half the fun is working on them....
An Andrews 27, with -.065 off the heads is a great set-up.
Adjust those pushrods to .140-.150" into the lifter and should be plenty quiet.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
I absolutely love the EV27. I had it in my 91 FLHS and that thing pulled wheelies!! I had some 9.8/1 heads on it too so as mentioned, a little increase in compression does help. It is a fast ramp grind so it can be noisy so I highly recommend you use your stock cam gear instead of Andrews. If your stock cam gear is worn then have a machinist measure the Andrews gear and find out what color code matches it then buy a crank gear to match it. Andrews says they have a color code red gear but I just did my neighbors bike and it was too tight so I measured it and it was a color code black!! Now he has to buy a different crank gear! If you get the gears matched correctly it won't be loud, mine wasn't. Enjoy it, it makes a really flat torque curve and even gets good mileage!!
I fitted an EV27 into my stock 1990. The only other mods were SE air filter, Crane ignition module and spiked mufflers. A significant and worthwhile improvement. Rode it that way for several years until I decided I wanted even more! You could simply fit it and try it. If you like it, the mods Scott suggested will make it even better! You won't be disappointed.
I think you'll find the EV27 predates those rockers!
