T-Man 625
Dalton...we have spoken before and what you say makes sense,just seemed funny his first response when I asked him was his 625 cam with his stage II heads.He then said I could use his 590..555...or his 525 as they are all very similar.I am looking to have better lower end and mid range performance as I ride in the 2000 to 4500 ranges with some 4800 to 5000.Have NEVER hit the limiter.
SO djl...you sayin go to a stage III HEAD AND THE 525/555....TR seemed to like the stage II/w the 625/590/555...just want a cam that performs where I usually ride.My little 88" with the 0033 Hq cams doesn't do too bad but runs out of steam after 4000...seems to fall flat....looking for roll-on 60...80 speeds to pass loaded 2 up....yea I can downshift but trying to get arm pullin power from 2000 to 55200.
We are a Tman dealer. We use the 625 and 590. they are great. Listen to TR he knows his cams best. My 2 cents on heavy bikes we stick with 590 instead of the 625 the 590 pulls a little better down low than a 625.
Both both are great cams and work very well. And plus 1 on Dalton post.
As for the heads, if I was looking for a little more boost, I would look to gain it from the head work, not a higher lift cam. But that is contrary to what many on this forum would do, after all, bigger is always better, right!
I am just a guy with two Harleys' in the garage and bad case of "tinkeritus"; certainly not in the same league as some of the pro's on this forum. I have no agenda other than to share a laymans experience, thoughts and knowlege, much of what has been learned through trial and error for other forum members to consider, or not.
DJL;I appreciate what you are saying i am just wondering why such a high lift cam for a 97" motor.I was told by bob woods to use his tw7h6r cam which has 575 lift and appears to make power in the lower rpms.TR said the 625 starts at 2200/2500 and pulls through to 6000.I have read that woods cams are noisy but feel that with 625 lift it will be noisy also.Probably need to have more conversations before I pull the trigger on a particular cam.I am not after a dyno king I am after a motor that delivers the performance in the range I ride.TQ<TQ<TQ and still be reliable.Cams are like women everybody has what THEY like I guess.
We have been installing and selling alot tm 555 cams you will be very happy. That cam likes comp like 10.5 and higher also My self and a few other shops have seen 10.7.1 comp and on 103 kit making 113 hp not bad. with just stage 1 head work HD 103 kit.
Enjoy keep us up to date.
The 590 is like it like the 662-1 cam but lower lift.The 590 builds more hp and tq across the board. The 590 comes real strong right 2600 tq and goes right across. not to change the subject but I have a set of 574 Feuling cams I sold to a buddys shop to put in a 110 inch with a blower I like the numbers Feuling is posting on the 574 cam also. And they claim no lifter noise and bolt right in a stock 96 inch motor.
The 590 I like for the heavy bikes. it pulls better than a 625. 625 from What I have seen it pulls more mid and top end. 625 Its a great cam if you plan on racing. MY 2 cents
