What kind of power can a stock crank take?
Any time is a good time to build up stock crank.
We have put about 125 hp on stock with blowers no probs. Also long as you dont beat the sh@#$% out of it. your okay. But what fun is that if you cant beat on it LOL.
We would like to see them all done from the factory would be nice.
But we like to say about 120 125hp then it time to beef it up. Than you you are pushing it.
But the new bikes the day they come from the factory.
My 2 cents.
My 2 cents.
A straight roller bearing eliminates the need for setting bearing endplay, which significantly reduces labor costs during assembly which is why the MoCo made the change in '03. However, a straight roller bearing cannot handle the thrust and the high loads generated by upgraded engines producing more TQ/HP than the stock engine was designed to produce. Once an engine reaches approximately 100 horsepower or more, normal crankshaft flexing at high speed can fracture the straight roller bearing's outer race. When that happens, broken bearing fragments fall into the flywheel cavity and end up circulating with the engine oil, destroying engine components and sometimes leading to catastrophic engine damage. Not a mechanical engineer but JMHO.
I ran across this looking into crank issues a while back. http://www.youtube.com/watch?v=9uh9FVm3Hv8
